Hello everybody! Just got my Mark V head few days ago from previous owner. Currently, it's played through a 2x12 Horizontal Rectifier cab. I'm hoping some of you experienced Boogie users and all-around experienced tone masters can give me some good advice and help me understand my new amp a lot better and get the most out of it. A bit long read ahead, but maybe some of you will give it 5 mins and understand.
First thing's first: A Little Bit about Me:
I am new to Mark series. I am new to Mesa Boogie. I am new to tube amps! For the last 12 years or so, I've always been on the budget, always opting for relatively cheap, used, solid-state amps with decent clean channels through which I've been running digital processors responsible for all my sounds (clean, distorted, reverb'd, delayed, chorused, etc.). My setup for last few years has been a Marshall Valvestate combo with BOSS GT-6 processor running everything in front of the CLEAN channel. I've mostly played in cover bands and done some original stuff too. Not much recording. I've learned to live with this setup, and learned to do it fairly well for my needs. I've been complemented on my tone several times (although they were probably not quite tone fanatics ). Nothing fancy, but I think I have managed to strike a good balance of things on the GT-6 (amp emulation + overdrive + reverb/delay/chorus/compression as needed, noise suppression, etc.), coupled with some old-school guitar volume knob work (I often tweak the volume knob as I play). The GT-6 was a HUGE improvement over some older Digitech stuff I used before that. The amp emulators sounded A LOT better to me. Btw, been playing with my Ibanez JPM3 for the last few years, which is now my main guitar.
I've been playing various genres, but mostly staying in heavy-ish ones (ranging from Gary Moore, G'N'R, and similar to Iron Maiden, Metallica, Dream Theater, Pantera, and now some Avenged Sevenfold, Killswitch Engage, etc.). I don't like over-saturated, overly scooped, overly modern fuzzy tones, but I do like to keep it on the "saturated" side of things, I guess. I play lead and rhythm. Bit rusty currently. :-(
Enter the Mark V
In my current band we're starting to do some more gigging and recording, so I finally decided to spend some saved up money on a good amp! I approached this is as needing to get the one amp I will spend a lot of money on now but will never need to buy one ever again!That's probably not going to be reality, but you get the point.
I know I like Petrucci's sounds, in general, so I figured I can't go wrong with a Mark IV or V for the basis of my tone. I'm not trying to copy Petrucci necessarily (yes, I know I also have a JPM3, but nevermind that :wink: ), but it's a good point of reference for me.
So, I'm pretty happy with my initial experience with Mark V, and my first tube amp ever. But I think I have a lot to learn. I've read the manual inside-out, and that helps tremendously, but I feel like I'm sort of in a transitional phase now, and I need to re-learn some things. It's probably that Mark V is not as forgiving as my previous setups have been, so I definitely feel like I have to work more to produce same results as before--but that's not necessarily a bad thing. Some things feel like "not enough gain/saturation," but turning the gain knob just muddies up things and doesn't really get me what I need. Do I need a OD in front of the amp? Feels like it's harder to do things like pick squeals, for example. I know this is far from ideal, but just how much could I get away with using the BOSS GT-6 in front to do some OD (no amp emulation of course)? Maybe I shouldn't put anything in the front and just keep tweaking the channel settings... So far, i can't decide whether I like IV mode better than Extreme. I can't decide whether I like Pentode or Triode better. :?: Do you guys have recommendations from your experience, at least based on the descriptions of music and bands up above?
The Loop
I know it be GREAT to have a nice pro rack unit, but it ain't gonna happen--not soon, at least. So it's going to be the GT-6. Mostly would need that for reverb, delay, chorus, and similar effects. One thing I'm finding is that I have to turn down the SEND on Mark V loop to 9 o'clock in order to keep the incoming signal on GT-6 in normal range. I fear that this is taking away too much of the amp level, as I have to increase the overall output quite a bit, and that the tone is suffering as the result (just by the virtue of having turned down the LOOP circuit so much--never mind the GT-6). Should I be concerned with that? I feel like I don't know my MKV well-enough yet to know for sure.
In Summary
So there you have it.... I apologize for the long post, but I feel like I'm really not able to fully "steer" the MKV yet, and I feel like my tone, whatever little I HAVE learned over the years, is gone now, and needs to be re-learned. Again, this is not necessarily a bad thing, but I wonder if I can get some advice and helpful pointers from you guys! Hopefully, this is not TOO specific to me, and other MKV or tube amp noobs like me can also benefit from this discussion.
A big thanks in advance!!!
p.s. I leave you with an old multi-track recording of me playing Satriani's Summer Song: http://dl.dropbox.com/u/4158419/SummerSong.mp3 (this was from like 7 years ago).
Enter the Mark V
The Loop
In Summary
