Regret
What is it for exactly?
cvansickle said:I had a DC-5 from 1996. They had removed the ground switch from the design by then.
Mesa IIc User Manual said:First, plug the AC cord into a wall socket and turn the Power switch ON. It is not always necessary to have the three-pin power plug grounded, and in some situations (such as multiple amp setups) a ground float adapter may reduce line buzz. The Ground switch located on the amplifier rear panel should be set to the middle position and switched to right or left only when buzzing line conditions warrant its use.
