Technical specifications:
Removed from a working amp and in excellent rust-free condition, and tested 100% working. The amps that this power transformer was designed to deliver over 200 Watts of valve power. This is a very heavy duty (and weight!) power transformer which can also be used in DIY projects. It's center tapped.
The tranformer has taps for 110/115v or 230/240v, depending on which primary taps are used.
link to auction:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=250286609834
Thanks,
Jonny
Code:
* Mesa Part no #561180 (identical to #561203, #561200)
* Serial number EIA606-915.
* A drop-in replacement for the following Mesa Boogie amps:
* Stereo Simul-Class 295 poweramp.
* Bass 400 / 400+ amp
* Baron poweramp
* Buster Bass
* Coliseum 300
* D-180
* M-180
* Strategy 400
* Power rating: 200Watts +
* Input voltages: (This transformer is for both Domestic and Export versions)
* 110/115v
* 230/240v
* Output voltages:
* HT center tapped
* Bias supply 60vac
* Heater 6.3vac center tapped
link to auction:
Thanks,
Jonny
