• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
FS: ADA MP-1 w/ Voodoo Amps Deluxe Mod
Warrior
Voodoo Amps Deluxe Standard Modified ADA MP-1 Preamp
"You'll be able to get tones that would normally cost between $2,500.00 to $4,000.00 but at a fraction of the cost!!"
Voodoo Amp Deluxe MP-1 Modification Description/Specs from Voodoo’s web site:
• All Modifications are exclusive to Voodoo Amps™.
• Restructure the gain – remove the fuzzy/buzzy characteristics & increase the gain/distortion.
• Improved note articulation – more articulate/defined/clear.
• No matter how much gain you use you can still hear all the notes within the chords.
• Liquid like sustain for days.
• Over all harmonic content is increased.
• Harmonics will leap off from the fretboard with ease.
• Tighten up & add bottom end – never boomy/tubby or woofy.
• Improved clean tones – more airy/chimey/open sounding & lush (more Vox or Fender like).
• Lows, mids to highs are much more balanced across the frequency spectrum.
• Cranked tones at lower volumes – Sound clips were recorded with Master on "1".
• EQ section is much more active and responsive allowing for unlimited tonal possibilities.
• Will cut through & sit in the mix much better live as well as in the recording studio.
• 12 new Voodoo presets are programmed (90-102) – same presets used on our sound clips.
• Download a PDF copy of the owners manual complete with (12) new Voodoo settings.
• Sound clips only demonstrate 80% of the gain on tap – Another 20% of gain is on tap to use!.
• (2) - 12AX7 preamp tubes are included.
• We replace the filter caps on the tube board only.
• All features & functions still operate the same – no holes drilled.
• We do not modify the FX-Loop or the switching system.
• No Add-On controls available.
• No custom modifications available.
• You can plug the ADA MP-1 into the effects-return jack on any head in order to use the head as a power amp.
• Voodoo Mods™ retain your amps resale value verses decreasing it.
• Voodoo Designed noise reduction modification.
• Voodoo spec'ed op-amp/chip upgrades - includes replacing op-amps/chips in the audio path.
• Improved gain tones as well as clean tones.
• Added bottom end that is richer/warmer.
• Greater harmonic detail.
• Recapping main power supply
A Deluxe Modified MP-1 costs $650.00 plus shipping from Voodoo Amps.
This is your chance to save some major bucks! This unit is in great shape with some rack rash.
Check it out along with sound clips at http://voodooamps.com/ampsforsale.html.
$550 Shipped in Continental U.S.
Outside U.S. contact me for shipping.
