Gentlemen
A complete success has been achieved
But perhaps not quite in the way I expected
On disassembling my amp I found that the previous owner had already performed the Reeder II mod – I re-wired and installed a switch such that I could hear the difference between the two set ups.
At the volume I can get my amp to in the house i.e. things falling off shelves, neighbours banging on the walls etc – this is only about 2 (8-O’clock) on the volume level. I personally couldn’t hear a difference between the two – however cranked at a gig this might be a different story.
Also bare in mind that the Subway Blues I have is a non-master volume, one-channel amp and as such has no gain control – if you want drive you simply have to have volume – ask Pete Townshend about this.
As I could detect little difference (at low volume at least) I’ve taken the switch out & just hard-wired it (as was) to the Reeder mod – I’ll go with Charles & Plan-X on this, I trust these guys.
The parallel resistor is a different story.
I had realised on my way to the shop that a 10K mid pot setting must already be available with the existing 0 to 25K mid pot – but I kinda carried on regardless.
When I got home yesterday I started wiring up as the diagrams above but two things hampered progress
A: The guy in the shop gave me a 68K resistor instead of 6.8K.
B: The mini switches I bought were far too feeble for the job – the one I tried the switchable Reeder mod with simply fell apart after I removed it.
So I made the executive decision to go with just the 10K resistor in parallel with the mid pot – 25K pot in parallel with a 10K resistor
This gives a value of 7K – very close to the 6.8K value of the Fender amps that had no mid control (quoted in Charles’ first post in this thread)
As the switches I had bought weren’t up to the job I rummaged around and found the switch that I taken out of my wah pedal when I converted it to true bypass
Then a little light bulb came on & I thought “ why don’t I make this mid shift foot-switchable?”
So I did.
The results:
To test - I set my amp with the bass & treble @ 12 O’clock & the middle on maximum – so I could definitely hear the difference.
Normally I wouldn’t set the controls this way. The mid would be set about 9 O’clock.
I used my “Antoria Rockstar” ( a quality 335 copy) & no effects – Just Guitar-Lead-Amp.
With the footswitch set to the 7K mid pot setting the sound was pure 1960s – I’ve never played it before but suddenly I’m playing “Bad Moon Rising” & it sounds Fantastic!
I played a little bit of bluesy scale kinda lead stuff and then switched to the 25K (original) setting & the whole thing just took off!!!!!!
Inadvertently what I seem to have achieved a foot-switchable “mid boost” option that makes your solo stuff just take off.
Wow!
Thanks to Charles for sending me down this route & of course to Bear for working out the wiring
I hope the neighbours aren’t planning an early night...
