• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
F.S. MESA ELECTRA DYNE 1x12 Widebody
jagon31
Up for sale is a Mesa Electra Dyne that i purchased a little under a year ago. It is still like NEW! This amp has not seen much playing time whatsoever, only been used in my home studio. I am currently selling off all my gear so my loss is your gain! I changed the Mesa 6l6 tubes to Tung-Sol El-34's , but still have both sets of tubes so you can choose whatever tubes you would like in the amp. Comes with manual, casters, footswitch and the padded slipcover which are all shown below.
Here are the specs-
This 1x 12" Combo Packs an Astounding 90 Watts of Power!
Though the Mesa/Boogie Electra Dyne Combo tube guitar amp features a very easy-to-use 6-knob layout on its front panel, you'll be blown away by its tonal flexibility. Inside its ultra-portable 1 x 12" chassis you'll find a powerhouse of an amp that's loud enough for any stage — the Electra Dyne Combo is capable of producing a hefty 90 watts, thanks to its Simul-Class power section (equipped with 6L6 tubes but compatible with EL34s as well). Great-sounding reverb, a bypassable effects loop, slave-out functionality, and 2-button footswitch are also included with the Electra Dyne Combo.
Electra Dyne Combo 90-watt, 1 x 12" Tube Combo Amplifier at a Glance:
* A ton of tonal flexibility lurks behind a simple front panel
* Dial in the power section of your dreams
* Add some "air" with great-sounding onboard reverb
The Electra Dyne packs a ton of functionality and tonal flexibility behind its front panel's simple-to-use, 6-knob layout. Deeply rooted in the best of the Brit lineage, the Electra Dyne takes modified English gain sounds and sorts them into Lo and High regions. These two choices are combined with a retro-minded, American-voiced clean "channel" and linked to one mini-toggle that gives you three of the most classic sounds in Rock and Roll on one switch! And unlike other amps of this style, footswitchable modes and the finely tuned control interface allow many players to stomp back and forth "across the pond" — without touching a single control!
Adapt the Electra Dyne to your tonal needs (and volume needs) with Mesa/Boogie's patented Simul-Class power section. It blends the efficiency and headroom of Class A/B Pentode operation with the sweeter clip and enhanced harmonics of Class A-style wiring. Choose between the Simul-Class quartet of 6L6 power tubes for 90 watts of authority or, switch down to a pair of tubes using Class A/B operation for a bouncy, easier-clipping 45 watts. You can also load the Electra Dyne with EL34 tubes for a brighter Brit-style voice, thanks to the switchable Bias Select function.
Want to add even more dimension to the Electra Dyne's great tonality? An onboard all-tube reverb gives you the lush texture you need, and it's voiced perfectly for this amp. The reverb circuit can be switched-in to be active in all modes, defeated in either Lo or High gain Modes (Clean remains active), or hard bypassed, which removes the entire circuit (including the Reverb tube) from the signal path — this flexibility makes it a purist's delight.
Electra Dyne Combo 90-watt, 1 x 12" Tube Combo Amplifier Features:
* Simul-Class power amp with 45W/90W power switch
* Tube complement: 4 x 6L6, 7 x 12AX7
* Bias Select switch (6L6/EL34)
* Fixed bias for consistent, maintenance-free performance
* Single-channel simplicity with the performance versatility of a multi-channel amp through three footswitchable modes (Classic Boogie Clean, Vintage Low Gain, Vintage Hi Gain)
* Channel control features: volume (gain), treble, mid, bass, presence, and master volume
* Slip cover included
* All-tube long-spring reverb with auto reverb defeat switch for Vintage Hi and Lo modes
* Reverb Hard-Bypass switch removes entire reverb circuit from amp
* Effects loop with automatic Hard-Bypass to completely remove when not in use
* Slave Out with level control
* External switching jacks for Vintage Low/Hi (clean is default) and reverb
* 17" aluminum chassis (rackmountable option available)
* 2-button footswitch (Classic Clean, Vintage Low/Hi)
I Still have the unregistered warranty (5 yrs) from Mesa. I am looking to get 1400 Shipped, but maybe we can make a deal! Pm me with any questions!
NEW PRICE! 1250 Shipped and pp'ed as a gift. (add 3% if you perfer regular paypal payment)
