jonnyrats
- Joined
- Jun 20, 2023
- Messages
- 2
- Reaction score
- 0
Hi all
Hope you can pop me in the rite direction . Got a used f50 a bit back . Loved it . Did 1 gig mint . When we got back into rehersals after about an hour a bizzare thing happens. My amp started cutting out . But only when someone else was playing theirs ? Singer sang thru pa . My amp died . Other guitarist / bass player played . Mine cut out. Then after another 10 or 15 mins mine was quiet as hell and noisey if that makes sense? Tried other tubes and was same after an hour . Bit the bullet and ordered the correct full set of tubes from Watford valves here in the UK. Took the amp to work and metered out the caps and resistors . All seemed fine . Re flowed the main solder joints . I'm a maintenance electrician so got a rough idea bit not electronic trained . Fit new tubes . Played quiet at home for half an hour fine . Went band practice and clean chanel was fine but drive channel had a vicious feedback howl . Used clean channel and after an hour same original problem again . Amp felt quite hot at the back . I know this is somewhat normal but ? . Love the amp but after paying 550 second hand and 200 on new tubes I'm at a loss. Anyone else experienced this before ? Is there a common problem I should be looking at ? Or anyone know any good mesa amp repairs in England? I'm in North West. Cheers in advance for any help . Amp had original mesa tubes in by the way when I got it . Thanks . John
