• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
EWI MB-MV Road Case for Mark V Combo Amp, & Casters. $ DROP
tptb73
This case is in very good condition. A few scratches and dings here and there, but they are solely cosmetic. As you can see from the photos, it actually looks quite nice. Casters will be removed and put inside for shipping. This is a very HIGH QUALITY case.
$175 Shipped & Paypaled
Ships to Continental USA only.
This is the EWI Tourcase tm Model MB-MV road case, which is a pullover style case, suitable for housing a Mesa Boogie MK V guitar amplifier.
The side panels are constructed with 3/8 inch hardwood plywood and covered with a black ABS laminate surface. The extrusion is all aluminum and assembled with aluminum rivets. The rivets on the 2 recessed handles are backed with washers to ensure strength and durability and the inside of the case is fully lined with 1" closed cell foam rubber.
The MESA-MKV case is equipped with 4 recessed butterfly latches to secure the cover to the tray and four 4" swivel casters are included, two of which are locking style. The casters mount to a 3/4" plywood caster board.
The EWI Tourcases are manufactured to exacting tolerances with excellent fit and finish. This is a well made case that is sized nicely to house one Mesa Boogie MK V combo amp, however: Check the dimensions of your amp for proper fit before ordering since your amp dimensions might be different.
Tough 3/8" plywood and ABS laminate panels
Recessed butterfly latches and padded flip handles
Large steel ball corners
4" swivel casters
Foam lined
Pull over style cover
Chrome plated hardware
Manufacturer: EWI
Model: MB-MV
Type: Pullover road case for Mesa Boogie MK V combo amp
Inside dimensions:
Left to right: 22 1/2"
Front to back: 11 3/16"
Tray height: 2 1/2"
Lid clearance: 16 1/2"
Total inside height: 19"
Outside dimensions:
Left to right: 26 1/2" measured at ball corners
Front to back: 15 1/4" measured at ball corners
Height: 27 5/8" measured on casters
Color: Black
Actual weight: 49 lbs.
Shipping weight: 60 lbs.
Dimensional shipping weight: 69 lbs.
Product Specs
Condition:Very Good Make:EWI Model:MB-MVFinish:Black & Chrome
