tony777
I bought a bias probe for the purpose of matching my tube collection, and today I had some time do go through it.
Though I am not a technician for amplifiers I work with electrics, but in the distribution, engine controlling area, so I am a bit familiar with power so to say.
Anyway.
I used my MarkIIC+ simul class which has plate voltage at 423V, and used a dual bias probe, so I can switch between the two measured tubes and it makes reading a bit easier. What surprised me was most was the difference between the current draw between Mesa labeled tubes. I have a collection of STR415's which differed from 23ma to 42ma, but most of them were around 35ish. A str420 was down to 25ma.
I have some TAD 6L6 and all of them were below 30ma. And so on. My Svetlana 6L6's were from 37 to 42.
But I found out that my Mark IV did not have matching tubes, they had a difference of 12ma, at the 6L6, and if that wasn't enough I have a pair of TAD EL34 which had a difference of 8ma. So I checked the TAD in my MarkIII, which had almost the same difference. Luckily I coud swap them so I got matching EL34's in both amps. The EL34 had a current draw from 37 to 44 in the class A socket.
So I continued with my EL34s
My STR416s had drew 56ma.
Winged =C= one had 20 and the other had 34....pretty far off huh?
I had 4 Sylvania 6ca7's which were faulty, one drew 13, and the other three continued rising until they were above 80, and then I chickened out and switched them off.
Even my barely used STR447 were faulty. One of them was shorting when I was turning the amp on from stanby.
So I don't have enough EL34's anymore.
So on to my question.
I put 6L6 in th class a socket. A svetlana pair of tubes draw 60ma. Is this value correct when a 6L6 is in the class A socket?
Well it has been a fun experiment, and after my MarkIV got matching pairs of STR415 and a matching set of EL34 TAD's sockets it really blew me away about how good it sounds.
Any comments or information is very welcome.
Anyway.
