Kramer,you are right.what sounds good to you is the proper bias point.The plate voltage has alot to do with what is the "safe" range.If your plate volts are high enough the 26-30ma's you select could very well be 50-70% disipation.But anyway sassuming the 32-44ma were 50-70% going to 26-30 is not likely going to put you into crossover distortion range.To me there are only two requirements to proper bias,first is that your tubes are not redplating and second,that they sound good to you.Some techs use the crossover method and to me that is just too cold for guitar amps,sure using a scope may seem "scientific" and precise,but it takes the most important piece of test equipment out of the formula,your ears.As to your comment about worrying too much about this and finding the right preamp and power tubes.If you have an adjustable bias you can use power tubes that otherwise wouldnt sound good with the non-adjustable bias resistor,and you can then concentrate on the preamp tubes.
