Controling Roadster Channels/Effects using External Switcher
dgandalf
I would like to control roadster amp functionality (switching channels, reverb/solo/fx) from a switcher/controller such as OneControl CROCODILE TAIL LOOP (http://www.one-control.com/crocodile-tail-loop.html) or SuperSwitcher 2 (http://www.superswitcher2.com) so I will be able to change both the amp channel/effects and change the other pedal loop in one click.
The way I found to achieve that is to buy this box (http://www.rock-gear.de/en/Guitar/Effects/Switch-pedals-Looper/G-Lab-MAC-4-4-MIDI-Amp-Controller-for-Mesa-Boogie.html) in addition to the switcher, in order to convert the amp controlling to midi so the switcher will be able to control it.
I wonder if there is another way to do that and avoid buying this additional box, like a switcher that already supports the roadster switching.
Thanks
Thanks
Well... This http://www.rjmmusic.com/rackgizmo.php would be a single device solution. Also you should have a midi board.. The price is kinda high and I haven't ever tested this myself but :lol: just an option.
I use a rjm mini amp gizmo i mount it on top of amp with small screws and washers through vent. controlls amp channels and other things like fx loop, reverb, solo, and i think tuner mute.
did some more research and found http://www.glab.com.pl/gsc-4_en this might work for you
I need the same solution - the GSC-4 looks like the ticket! Roadster needs alot of relays but would like to add pedals too - it looks like this is a one box solution
