I've had my V since they first came out. I mainly used clean and fat on channel one (45 watt mode). I have noticed that the clean channel was quite a bit quieter than my crunch. I never really messed with the rectifier switch after setting it how I liked when I first got the amp. I moved the clean channel from tube to solid state, and that gave me a nice boost in volume. Just an fyi in case have problems with volume mismatch. On the filp side, you can drop the volume of either channel by running tube rectifier on 45 mode.
Also, the clean channel get a nice mild OD on tube rectifier with the gain around 1:00 (channel volume noon, master volume 10-11). Flip the power switch down to 10 watt and the same gain/volume settings get a nice, low volume crunch. That's on both the clean and fat modes.
