• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
Carl Martin Single Channel PlexiTone Pedal -SOLD
robberns
Massachusetts
New in the box, bought a bunch of OD pedals to audition. This has way more gain than I'd ever use. Cool sounding pedal if you are looking for the plexi-type distortion.
Used for maybe an hour at most. Includes box, no velcro on bottom.
SOLD
"The new `single channel` Carl Martin PlexiTone was designed in association with Pete Thorn, and is housed in a small pedal-board friendly housing with 3 knobs and 1 switch. Apart from Pete's slight modifications that give this new pedal a tighter bottom-end and slightly softer high frequencies, it is exactly the same gain structure as the High Gain setting on the original Pro-Series PlexiTone....it just plays better with different amps. The single Plexi also incorporates our new DC-DC converter circuitry, so the pedal can be powered by a regulated 9V Power Supply but will still operate on the same +-12V level as the original AC powered PlexiTone. This allows us to use the same high quality components which provide the same tone and headroom that make the CM Pro-Series stand out from the rest!"
