caliber 50
ti479
on the caliber models with a graphic EQ the rocker switch that controls it, is marked auto then the center amd then the bottom is EQ IN. how do you turn it off so i can just use the regular knob settings? i know one position is on amd other only turns the eq on when in lead mode so which is which?
Set the rocker switch to the center. If the EQ is still active, something is wrong with the rocker switch contacts and should be replace.
