94Tremoverb
- Joined
- Dec 5, 2009
- Messages
- 1,340
- Reaction score
- 0
giorikas81: "Then again the rectifier and the 5150 are both soldano knockoffs of the SLO preamp...with some minor differences."
No they aren't. That's one of the biggest myths there is out there in internet-land about amp design.
First, the Rectifier is not a SLO knockoff - it certainly is partly based on one, in that the overall layout of the first few preamp stages and a few specific and crucial (and very unusual, which provides enough evidence that it can't be a coincidence) resistor values are identical. But after that they are completely different - the channel switching, clean channel, FX loop, negative feedback circuit, and power supply are totally different and unrelated. So, you could say it shares some of its initial preamp distortion voicing with the SLO... but that's about it.
The 5150 has nothing in common with the SLO whatever... apart from the fact that it uses multiple tube gain stages and has generic gain stage resistor and cap values in several places. The whole circuit is utterly different, and in particular the Peavey has no cathode-follower stages - the SLO has two, as does the Rectifier but they are in different places. If anything the 5150 is more similar to a Mark series in that all the stages are plate-output... but it's still not remotely related. The 5150 II does actually have one cathode-follower, but it's purely the FX loop driver and does not feed the tone stack as it does in the SLO and Rectifier (and all the circuits derived from the classic '59 Bassman/Marshall JTM45) and which is a fundamental part of their sound. The SLO actually has two of the exact type of DC-coupled cathode-followers which are V2 in the Bassman/Marshall, cascaded one after the other... the Rectifier does not, it only has one (the other is configured differently as the FX loop driver).
I don't know where this myth has come from, or how - one look at the schematics of all three amps by anyone who has the faintest clue how to read one and it's immediately obvious they are not copies of each other, and the Peavey is not remotely related to either of the other two. The two versions of the 5150 are very different from each other too.
