2 channel triple rectifier footswitch
kflow
Hi all,
I just got a 2 channel triple rectifier. What footswitch will work with this amp?
Help guys! My new rectifier will be here on Thursday and I want to have the footswitch when it gets here..
Nearly any single button footswitch should work on that amp. It's just a switch that shorts the two conductors in the cable together. Try this, get a large screw driver, plug a cable into the amp, and use the screwdriver to short the tip of the cable to the sleeve. See it switching channels, the footswitch does the same thing.
I have the old footswitch for the two channel triple rectifier, and after I opened it up... I cancelled my order for a new one, isnt worth $59.00 from mesa. You can build you own, like he said any single foot switch will work.
