My band did an outdoor show and I kept getting major volume spikes coming through my amp. I'd be playing and suddenly the volume would raise really high for a second or two then kick out of it. It wasn't until I got home and hooked up my head today that I think I found the problem and I know the gurus here will have a solution or at least great advice!
I run my individual channel master volumes at roughly noon. I adjust the master level to taste (whether at practice or performing in a venue) I don't mess with the channel volumes at all since I have the amp dialed in just where I want all three channels.
I have the foot switch control set to FTSW and keep the loop active at all times. I activate the effects I want via my floor board.
My Send is at about 11 o'clock (any higher and I get too much noise)
My Return (mix) is just about max
Front end: (wireless or cord) Guitar > Morley Bad Horsie 2 Wah > Boss TU-2 Tuner > Morpheus Drop Tune >Boss CS-3 Comp/Sust > Boss BF-3 Flanger > Way Huge Green Rhino Overdrive MkII > Boss NS-2 Noise Reduction > Morley Optical Volume > Front input.
My loop goes: DR SEND >Boss CE-5 Chorus > Boss DD-7 Delay > BBE Sonic Stomp > DR RETURN
Last night I experienced volume "surges"
I had the Master Volume at about 11 o'clock
Today I hooked up JUST my footswitch and ran my guitar direct to the front.
I put a patch cable from the SEND to the RETURN.
Here's my diagnosis:
With the FTSW engaged and the Master Volume at about noon I'm just not getting volume. This thing should stupid-loud!
I switch it to "Loop Bypass" and Wham! I get the individual channel levels which are much higher.
Switch it back to FTSW and it's almost like it cuts my volume in half!
Theory: With my Master volume at about 11 o'clock position during the show I wasn't getting the volume and once in a while the ACTUAL setting would kick in and I'd get a brief volume surge.
I've had the amp for just over a year and bought it new.
Thanks for looking and any advice would be greatly appreciated.
