Mesa 5:50 plus switching
Sowden01
Hello all,
I have recently bought a Neewer NW201 1 button footswitch with LED to try switching channels on my 5:50 plus head. This keeps the real estate to a minimum and its the only thing I really switch (at the moment anyway), so a good fit.
When I plugged it in, it will switch the channel in one direction but not back again. I'm connecting with a 6.35 Jack to Jack - both stereo and mono leads give the same effect.
I read on one of the posts about stiletto switching that you could wire a stereo lead in a certain way by putting a mono jack on one end, which would work in the case of the Stiletto.
Could anyone shed any light or offer a solution?
Many thanks in anticipation.
Cheers,
Russ
Hello.
I think you cannot use footswitch with led in external switching jack.
Hi, thanks for your response.
So if I rewire to exclude the LED, it would work ok?
Cheers,
Russ
