erickompositör72 said:Honestly, I would take some time to dial in a much richer tone. At least, the way you recorded it, everything is coming across as fizzy and almost like the cabinet is lying on bed facing down. Based on the settings I see, a lot may have to do with you GEQ setting, and I'd also avoid having the treble on "10" on a StudPre- especially with the ++ mod!
These amps are capable of so much. If you listen to Master of Puppets, there is this juiciness and bounciness in the rhythm. Very "3D" sound.
Of course, this is just one person's opinion. Your playing sounds good, so I'm sure you'll end up with some nice tones. Good luck!
JD said:The sound I get in the room is spot on, the mic setup is not the best a Zoom Q3 video recorder in a small room. I had the recorder set up about a meter back in the middle of the floor, I will try to do a better one
It is set up for playing not recording sort of just wanted to give a comparison
Enter your email address to join:
