Boxy ?
GuyB
Boxy ?
Post by GuyB » Sun May 16, 2021 8:27 am
Just received my Fillmore 25 head and the Fillmore 19 cab. Sounds a little bit boxy, whatever the settings. Could it be because the speaker is not "broken in" yet ? If so, how long to break in a speaker ?
Markedman
Re: Boxy ?
Post by Markedman » Sun May 16, 2021 10:46 am
There are many factors in determining what causes boxiness in tone, from the room you're in, speaker break-in, guitar pick-up, settings and of course, whether you are comparing amps.
A typical speaker break-in period also depends on volume and duration. If you play in a band, after the first practice you'll notice a slight change, after 20 hours at band volume level you will notice a big difference.
GuyB
Re: Boxy ?
Post by GuyB » Mon May 17, 2021 7:38 am
Thanks very much.
plan-x
Re: Boxy ?
Post by plan-x » Mon May 24, 2021 1:04 am
Is that a C-90 Black shadow?
Fillmore 25 head
Lonestar Classic (LSC) 2x12
John
Plan-x
GuyB
Re: Boxy ?
Post by GuyB » Mon May 24, 2021 8:18 am
It's a Celestion C90.
GuyB
Re: Boxy ?
Post by GuyB » Mon May 24, 2021 8:20 am
Sorry, yes it's a Black Shadow.
GuyB
Re: Boxy ?
Post by GuyB » Tue May 25, 2021 1:19 pm
When you asked the question first, plan-x, I was not near my amp so I went to Mesa's site to see what was the speaker inside the Fillmore 19 cab and it says " Celestion Custom 90". So that was my first answer. But just to make sure, I went upstair, where is the cab to check what was in it and there it was, in big bold black " Black Shadow". So, that was the second answer !
Now, are they the same speaker the "Celestion Custom 90" and the Black Shadow" ?
plan-x
Re: Boxy ?
Post by plan-x » Sun May 30, 2021 3:13 am
Yep, same speaker. I'm going with the break in theory also. Scoop your mids a bit to compensate for Boxiness? Generally 1x12's will be boxier than other cabs. I have a 1x12 open back, no name cab with a C-90 that sounds good with my Fillmore. Really good! Play the snot out of that speaker.
Fillmore 25 head
John
Plan-x
soonermav
Re: Boxy ?
Post by soonermav » Mon Jun 14, 2021 12:21 pm
OP, how does the 19-inch cab sound now that the speaker is broken in?
I've got an avatar contemporary 2x12 through which my Fillmore 25 sounds amazing. Problem is, I don't want to always lug it around so I'm looking to get one of the 1x12 cabs for rehearsals and smaller shows.
Do you wish you have gone with the 23-inch cab or are you happy now that the speaker is broken in?
GuyB
Re: Boxy ?
Post by GuyB » Sun Jun 20, 2021 11:46 am
Like Markedman said, the "boxy" sound is quite complex. But things are getting much better. I think that the main reason was on the side of the speaker. I don't play often at the moment and not loud at all. It took all this time to see that there is now a good difference now that the speaker seems to be broken in. Every day sounds better and I'm already enjoying the quality of this super amp. Thanks all for your inputs.
For "soonermav", I don't know what the 23 inch cab would do but I can assure you that the 19 is, for me, like a dream.
Gordybaby
Re: Boxy ?
Post by Gordybaby » Sun Jun 20, 2021 12:51 pm
My favorite speaker so far for my Fillmore is the Celestion Redback I have had it in a open 1x12 and a closed 2x12 spectacular rock sounds.
CoG
Re: Boxy ?
Post by CoG » Sun Jun 20, 2021 6:08 pm
Off topic - your username seems to tell me 'fellow Canadian...'
Dual Rectifier Tremoverb 100 Head
MkIII Green Stripe DRG
Royal Atlantic RA-100 Head
Recto Trad 4x12
Also owned: Rec Pre, 20/20, Bottle Rocket, a bunch of Mark IIIs, a bunch of Rectos, a bunch of Mesa cabs, a bunch of other amps
