Which amp sounds like a Mark and Recto mixed?
- Bottle Rocket
Anyone know if there is an amp that exists that has the roar and oomph of a Recto and clarity of a Mark? I own both a Mark IV and a Dual Rect. Or are there any pedals that I can use with the Recto to achieve the clarity of the Mark? Thank you.
Re: Which amp sounds like a Mark and Recto mixed?
try going on the Recto's Modern channel, bold, diodes. Put bass at 7-8 o'clock, mids a little bit higher but still below 9 o'clock, treble at 1:00. start with the gain just below noon and the presence at noon. leave the mids and bass where they are and tune things with the treble, presence, and gain.if it sounds thin and bright mess with the presence first, if that doesn't work add bass in tiny increments.
master at least 9:30 but ideally you want to turn it up until you stop hearing a volume increase (this'll probably be right around noon) and then turn it back one "hour."
make sure the loop is not engaged.
If you have a cleanish boost with some kind of tone stack (I like the Xotic RC Boost) use it to nudge the amp and cut some of the bass coming from your guitar.
Rectos can do this, it just takes some tweaking. And volume helps.
Dual Rectifier Tremoverb 100 Head
MkIII Green Stripe DRG
Royal Atlantic RA-100 Head
Recto Trad 4x12
Also owned: Rec Pre, 20/20, Bottle Rocket, a bunch of Mark IIIs, a bunch of Rectos, a bunch of Mesa cabs, a bunch of other amps
Recto Trad 4x12
- Bottle Rocket
