Mark5 Footswitch schematic
kiff
Tx
Hi, long time since I've lurked here :)
I'm looking for the schematic for the m5's footswitch. I want to activate an external effects loop to add a compressor for the clean channel. Not sure how much logic is in the footswitch, so it might not be as easy as using an optocoupler on the LED's power, but I figure it's worth at least looking at it, but can't make google produce the schematic
TIA
-Ken
Sure there's a pinout for the footswitxh connection on the board here somewhere? Worth a look if that might help.
I posted a copy on here and don't know where it went but it's in one of the threads. There is so much **** in that pedal, I highly doubt it could be modified. **** ton on tiny relays & all that good stuff. It's packed.
Thanks guys, I don't really need it anymore since I went back to my my mark4. I still wanted the functionality, but I opted for a less intrusive option. I made a looper that's light activated with a light sensor that's velcro'd to the footswitches channel's light
(this video was still on the mark5 and before I added velcro)
https://youtu.be/Fv_DKg9yk8w
Wayno said:
Cool, works well, dunno if I'd trust it on stage though 😉
Haha yea I was a little skeptical at first, but I put some effort into that. Heat shrink tubing around the photodiode's leads, vecro'd to the footswitch and then a strip of electrical tape over that. Used some fairly thick speaker wire to a 1/4" jack to the unit. It holds fine. About a dozen rehearsals and 3 gigs so far, not a single hick-up :)
hS4OQ2V1SZdsTSYzit4UR32yRk5lIKt3iG9NX65DMFRdeuyQycjkEUX9f1tj2kb0zeJVr5CWvR8o5Iy5svOskUuLwhbIQVwP7A4fmAh8UNdM_4mgqUaOXSfst8HYflz2vyKFPorCXmckxHM9z4h269n6IW14LCVsSD9WMYfupjSLWhHSBHoskKqTj0nCdnnY2JDoFzM3cnoatI4tP_PY68J5YzM4Dazw9vwYPKGsRFUwsRGqhgHxSm30RFijt1D_hgdVA3fJYKHcgZgHIUoEPp7Xx3dGpWdSTX4Zsi_5MzHABheQaq_06xSgA2aDkl3b_E7GDjKc0DIQJDymmASfb3bfj9EpgVjO4uk4ZOqBnCVEQylMmAzOltLDpYOQVsheXg0bjYb7HQQkQvtl8q_aefkh7YZQjnyshrCDyQlqA81Dh3-fqBUZTdXAMwh4PPnagiksX1MrFa8ozaq_eemlSRoS14tfr11KPlyG2C2wbLT1c2h5-vsv7gptVKQCbTYZORl5027HEozk3sGO-Hpt3d0IeO8ZoXVl82lc2hmzuCKbfZIFolyl54C_wCyhPbqqLz1ISKGAJeuMUTTxwElA9DW-9SwKxh6aZtK-s3FuPdK0Q-S-HoRkTcStBD71-JpvtzJKz0zOe3wWfCnjTWaKa678rM0bgsGM5ZCi_a7yjrKqDRNFBu2WGbV9Y-OtuQZlHkRUYT1Ayh7_WVpevQZgWYkVlOr6gWEH6iCSySrj7nuG0BwBfs8VQZfrsiBD_hFmwf4MX_4wnhbq1tUpnTtLDPz9gyfWCUVt8dopntH2ka6J2tsiAh_C3uy5Ajp8spoHt8cTJsf_4n2ux6Fme2x7qLi2tmv0bhXfkEXIvtMsOOiGpyGmtKqwFZuQSPeRt6URQjNBQIHcZCJCJM8nyc55NrlSm94ksBLneFaSM9Q=w649-h865-no
