I have bought a second hand Head 10/50/100 in mint condition.
The amp is wonderfull also at bedroom level.
Yestraday I'm tried to place the flashback 2 in the loop, but I can't understand how set the levels properly:
the pedal is in truebypass and every time I switch it off the volume drops a lot.
This happens until I set the send level of the amp to the full clockwise position.
I thought the problem had to do with the impedance of the pedal but I read in the manual that the Flashback 2 has 1MΩ in input and 100Ω in output, exactly the same values of many pedals .
I tried also to raise the master level without success.
If the pedal is set in buffered mode the issue obviously disappears.
Have you any idea why it happens?
