b00g13mk2B
- Joined
- Jan 12, 2014
- Messages
- 164
- Reaction score
- 7
I haven’t found a schematic so am hacking the big footswitch layout/operation. Going for a two switch with LEDs to fit my pedalboard.
Got a 2 position Mesa footswitch and added a DIN connector so I can use the same cable as the big footswitch. Bringing the Solo signal to ground via one switch works and lights the LED. The Channel select signal works differently, there are two signals associated with this, looking at the PCBA legend. Believe one works like solo and the back panel 1/4” jack, to cause the channel switch. The other may be LED drive. I’m OK with single color on/off LED instead of bi-color.
Has anyone done this hack and have a schematic?
