woodbutcher65
- Joined
- May 4, 2018
- Messages
- 590
- Reaction score
- 220
I've had a Mark IV widebody combo for a few months now and I haven't really had a lot of time playing it yet, because it's doing something that I can't believe is normal. I'll try to explain it clearly.
I'm in the lead channel with the drive turned up most of the way. I'm getting a good tone. BUT...if I have my guitar volume full up and I strum hard, it causes bright, harsh harmonics to come out that are considerably louder than anything else. It's like I've got a second amplifier connected and it's set louder, with a trebly tone, and it is connected thru a gate. When I strum hard enough, the gate opens and the second amp goes to work.
I thought it might be leakage from another channel, which would be affected by the master volumes and output volume. But no, not in this case. The behavior happens at any set volume level
The Mark IV is in very good condition and was recently serviced. I did a full preamp tube swap and that had no effect. While the filter caps are original, I know the symptoms of bad filter capacitors and this checks none of those boxes. I'll recap the amp anyway, some time soon, but it's not critical and can be left for another time.
