Single Rectifier Tone Stack ?
dafxtone
I'm searching details about my single rectifier tone stack.
V1A,B & V2A are marked as gain, but which one is the tone recovery ?
Also, i've compared the Lead channel with the one in the mini serie : V3A&B are indicated as cathode follower/Tone Recovery in the mini, but simply marked as gain in the single ? So i suppose it is the same for the single (just indicated as "gain" in the manual) ?
(Please don't reply this thread if you don't have valuable knowledge in electronics, thanks).
I’m the single Rec V3b is the cathode follower/tone stack driver. After the tone stack it goes straight to the fx loop V4 a: driver b: recovery. When you have a cathode driven tone stack you don’t necessarily need a recovery stage.
