Mesa HIGH-WIRE™ DUAL BUFFER & OUTPUT BOOST
Forum specific news and announcements
Pauley24
Post by Pauley24 » Fri Apr 28, 2017 8:16 am
I am planning to add the HIGH-WIRE Buffer to my board and would like to hear from those that use this buffer and their comments.
Cali_Cave_Man
Re: Mesa HIGH-WIRE™ DUAL BUFFER & OUTPUT BOOST
Post by Cali_Cave_Man » Sat May 13, 2017 12:44 am
Interestingly enough, I have the stowaway and the highwire. I bought the stowaway without realizing the high wire was out there. Once I saw the extra features I bought the high wire too. I'll use the stowaway for my bass rig.
Both products work great. I do use the tuner out so that my tc polytune connects through that instead of in my signal path. It works great. The tuner is on all the time and the press and hold mute on the highwire works fine. The only thing I would say isn't as good is the boost. I turned that thing all the way up and it's not boosting much. The boost is supposed to provide +22db which would mean if I'm at 80db and have the boost knob all the way up, I should hit 102db, but there's no way that's happening. That would be much louder and it's not. Other than that, the buffer itself, the mute, and the tuner out works great and my tone is great with it.
I also added all Mogami cables to my rig to go with the buffer. My Roadster has never been so nice and quiet since doing all this. I'm very glad I have the new cables and the buffer.
screamingdaisy
Post by screamingdaisy » Sat May 13, 2017 10:07 am
The High-Wire will boost the signal going into the preamp by up to 22dB, but that won't typically produce a 22dB volume increase out the power amp, particularly if your preamp is already clipping.
If the preamp is already clipping you'll get a slight increase in distortion and maybe a bit of extra sustain with no volume change. Most people will use a clean boost if they want slightly more dirt for leads without changing the overall sound, or to compensate for two guitars with different output levels (Tele and Les Paul for example). It's not really going to be an in your face effect unless you're plugged into a totally clean amp.
Cali_Cave_Man
Post by Cali_Cave_Man » Sun May 21, 2017 1:40 am
Ahh great point. That makes sense. So, it makes sense then that it will help compensate possibly for slight differences in guitar pickups maybe if I need it.
Thanks.
TriggerRob
Post by TriggerRob » Mon Jan 10, 2022 8:42 pm
Good evening ladies and gents. I have a question about this High Wire buffer I just bought used
So... this buffer is active and doing it's buffering job when it's got power to it and routed correctly yes? I don't need to have the boost engaged to get the effect as if it's an ON/OFF switch right?
Also...the decibel boost toggle... Does that only work with the boost when it's activated or does it have an effect on the signal without having to engage the boost?
And...I was interested in hearing a setting preference from someone whose currently using one. As in..toggle position ..boost always on, never on, sometimes on...etc etc.
I will say this ..I immediately plugged it in when I got it, used the tuner out and put my overdrive after it...I absolutely heard the difference in clarity, articulation and all around crispiness of the sounds I heard. It really really sounded great and def made a difference. I had no idea the sound quality would b as good as I heard it to be.
Anyway...can anyone help me out with the question?
Thanks a bunch
Dual Rectifier 2 Channel
Egnater Tweaker 88
