Which preamp tube is broken?
user 39637
Hi.
In my Express 5:25+ amp, a while back I started noticing that there were less overdrive on the burn than before. Or at least, that's what I think I'm hearing - it's possibly that it's just me, but I do think it is the case that it has lost some overdrive/power.
Then, about a week or so, I suddenly got quite a drop in volume on the crunch channel. It does seem like it's a drop in volume only, not the amount of drive. On the other channels I haven't really noticed anything different, even when switching between different wattage settings, so I don't believe it's the power tubes.
Assuming I have issues with one of more preamp tubes, how would I go about figuring out which one(s) are bad? Do I pull one out, play my guitar while trying out all the different settings and channels, and repeat for all preamp tubes?
Never mind, I'll just try and swap out one tube at the time, and see how it goes.
