Question for any amp tech out there
thinskin57
I’ve a Bad Cat Cub15R Player Series. This is a PCB amp with a digital reverb. I noticed that the reverb has developed hum. The higher I turn up the reverb, the louder the hum. I sent Bad Cat a video demonstrating the problem and they said it’s likely the bridge rectifier.
There is zero hum when I turn the reverb all the way down. I’m fine with this as I don’t use the onboard reverb anyway but I just wanna make sure I’m not damaging the amp by not repairing the bridge rectifier and running it as is.
