Since I converted my Mark V head to a combo, I could not use the MC90 speaker that came with it as it was damaged. I bought the combo shell used and only cared for the reverb tank and condition of the shell and coverings. I did have two MC90 speakers, one was removed from the Mark IV combo as it was blown. the other was the one that came with the combo shell (dust cap was falling off and flapping. Tried to glue it, did not work. Paper cone also had a wrinkle in it so did not sound ideal when used.) No big deal as I had plans to use EV speaker anyway. EV was ok, blossomed at higher volume but not ideal at lower settings. Perhaps the tone or low end character or lack of mid hump was reason to try other speakers. Jensen Blackbird was next in line. Sounded great once it was broken in but did a low frequency burp at elevated volumes. Put EV back in, then returned to Jensen but pushed a screw though the web and well, not good. Works great in my Carvin V3MC combo. Note that the damaged MC90 also sounded great too in the Carvin. Before I bore you to death with back story (bla bla bla...). Last I had the Celestion ALNICO 90W Crème. One sweet speaker and cost about same as EV. Unfortunately since I channeled the JP-2C though it, the Crème 90W never sounded the same since. Suffered a tone shift. Not sure if it was caused by overheating the voice coil as the bell was reall hot after that happened, the smell of something burning was also a tell tale sign that was not good. Had that happen to a WGS BlackHawk HP100. Once you smell it may as well replace it.
MC90 on order. Took a while to get it from Mesa. I was not impatient as it did arrive this past Friday. Was busy setting up a Drum kit and figuring how to tune it so my attention was else where. Last night I popped the MC90 into my combo. Had the option to put the label on the driver such that it was showing Black shadow across the top since I had to index the speaker to keep the connection tabs to the side vs the bottom. Speaker cable was getting shorter every time I changed speakers. Looks great but most of all, sounds incredible. I will give it some time to break in. Also hooked up the horizontal 212 cab to the amp to compare. I love both separately. Running the horizontal 212 with V30 and the MC90 combo at the same time was heaven. I never would have known how impressive that sounded. Now I am dying to get a Road King 412 cab..... That would be cool. Perhaps I have been too far removed from the MC90 as it was too hard for me to bond with it in my Mark IV combo I had for 16 years. Must have been some changes over the years. Also noticed that the new MC90 was made in the UK. I will have to check the sticker on the side of the magnet from the old speaker that came with the combo shell and see where its origins are.
One last note: The Mark V combo never sounded better. I was really considering unloading the Mark V but now I am much happier that I kept the amp even after the JP-2C has taken me by surprise. The Mark V still has a future in my collection and do not have the "I wish I did not sell it" regrets.
