Can a G Major 2 be used in 2 loops? Mark IV and V in stereo.
Guitar and bass FX discussion
SonVolt
Post by SonVolt » Sun Dec 15, 2013 10:26 am
Let's say I have 2 standalone combo amps, Mark IV and V, each with a series FX loop. The G Major 2 has a Left send/return and a Right send/return. Can I run amp IV to the left side of the G Major and amp V to the right side and get a stereo setup?
I know people run stereo with stereo poweramps but wasn't sure if I could do the same using 2 combo amps. I don't want to slave anything, I want both amps to use their preamps/poweramps.
domct203
Re: Can a G Major 2 be used in 2 loops? Mark IV and V in ste
Post by domct203 » Sun Dec 15, 2013 12:51 pm
I don't see why not. Just check for the usual stuff- ground loop hum, signal phase issues etc.
How do you plan to split the guitar signal into the front end of the 2 amps?
Dom
SonVolt
Post by SonVolt » Sun Dec 15, 2013 1:02 pm
domct203 wrote:I don't see why not. Just check for the usual stuff- ground loop hum, signal phase issues etc.
Dom
It's being split with a TC Flashback pedal that has stereo outs into the front of each amp. I have a ground lift on one of the amps to eliminate hum.
Would using both amps FX loops into the G Major result in stereo effects? Would it be dual mono?
domct203
Post by domct203 » Sun Dec 15, 2013 2:47 pm
With my G Major the Reverb & Delay is stereo for sure, and I believe the modulation block is as well.
This results in a true stereo image. Check your owners manual, it should tell you what effects are stereo.
Dom
