Possible issue with my Mini Rec
metalgarth
Post by metalgarth » Thu Nov 01, 2012 12:30 pm
On the red channel, is it normal for there to be slight output even when the Master is set to zero? My Mini Rec is doing this and so is another one at a local store.
Seems weird but if this is normal then there's nothing wrong with either amp.
Mesa gear: Mini Rectifier 25
elvis
Re: Possible issue with my Mini Rec
Post by elvis » Thu Nov 01, 2012 1:56 pm
I would guess normal. There is signal bleed around most parts of the circuit via the tubes.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
metalgarth
Post by metalgarth » Thu Nov 01, 2012 2:23 pm
elvis wrote:I would guess normal. There is signal bleed around most parts of the circuit via the tubes.
Does your Mini Rectifier do the same thing?
elvis
Post by elvis » Thu Nov 01, 2012 4:03 pm
Not sure. I can't think of a reason to run it with Master at zero.
Recto 2x12 Vertical
Recto 2x12 Wedge
domct203
Post by domct203 » Thu Nov 01, 2012 4:43 pm
elvis wrote:Not sure. I can't think of a reason to run it with Master at zero.
:lol: :lol: :lol:
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V - sold
'18 TC-100
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
TC G-System
==> NOMAD on Facebook <==
metalgarth
Post by metalgarth » Thu Nov 01, 2012 7:04 pm
I talked to Richard Duval(sp?) at Mesa and he says this is normal. It still seems weird to me.
elvis
Post by elvis » Fri Nov 02, 2012 12:46 am
In most Mesa amps, the Master is before the loop, so it is really more of an FX send level control, not an output master.
Again, in most amps, there is signal bleed around the FX loop because each preamp tube is actually two amplifiers. There is almost always a tube that uses one channel (A) before the loop, and the second channel (B) after the loop. There is crosstalk inside the tube, both mechanically and electrically. So you get signal bled around the loop, and it is not attenuated by the master because the master is pre-loop.
This causes problems when you use digital effects in the loop, because you need to have a 100% series loop, and the signal bleed makes even a series loop just a little bit parallel. The problem is most troublesome when running low volume, because the signal bleed is more obvious then. It gets totally swamped at high volume.
Hope that helps.
Recto 2x12 Vertical
Recto 2x12 Wedge
Adambomb
Post by Adambomb » Fri Nov 02, 2012 9:50 pm
metalgarth wrote:On the red channel, is it normal for there to be slight output even when the Master is set to zero? My Mini Rec is doing this and so is another one at a local store.
Yes every Recto I've owned has done this even with Master at Zero. It's normal.
