It is currently Thu Jan 24, 2019 12:20 am
PostPosted: Mon Jul 26, 2010 8:21 pm
I'm using a m-audio fast track pro interface with both garage band and logic and I really need to find some headphones that won't bleed the sound out to the mic. Also (off topic) how can I raise the sound on the click on garage band? Looking for something that's affordable. Ideally closer to $50 but I'm open to things up to $100. Thanks!
"Music is worthless unless it can make a complete stranger break down and cry."
"There are only two kinds of music; music that sounds good, and whatever you want to call that other stuff."
PostPosted: Tue Jul 27, 2010 10:58 am
I'd recommend the Sennheiser HD 280 Pro headphones. They run about $100, though I'm sure you can find them a little cheaper somewhere. These are great for recording and they attenuate the environmental sounds pretty well, so you can hear clearly through the phones. When tracking guitars, I can hear the track through the headphones clearly without having to crank up the volume.
PostPosted: Tue Jul 27, 2010 10:57 pm
Awesome! Thanks!
PostPosted: Fri Jul 30, 2010 9:57 pm
dbsens03 wrote:
Awesome! Thanks!
No problem. I hope those work for you. I love mine.
PostPosted: Tue Aug 24, 2010 2:27 pm
Late to the party, but +1 on the nod to the HD280 Pro. They're also "neutral" enough to pass muster for headphone mixing, if you need to mix that way.
PostPosted: Fri Aug 27, 2010 9:52 am
not just to throw a kink in the chain, but if you're NOT using monitors to mix (almost no pros use headphones alone to mix to)...
then you need to get some much better headphones than 100 bucks will allow.
'81 Mark 2B head ~ 60watt-GEQ
BatsBrew
http://www.cdbaby.com/cd/batsbrew
https://soundcloud.com/bats-brew
PostPosted: Wed Sep 01, 2010 10:11 pm
If you know the frecuency response of your headphones you can make decent mixes.
- Mesa Boogie Dual Rectifier Roadking II
- Mesa Boogie Mark IV
- Triaxis/2:90
- Mesa Traditional 4x12 cab
- TC Electronic G-Major
- TC Electronic G-system
- Furman PL-PLUS II Power Conditioner
PostPosted: Tue Sep 07, 2010 4:14 pm
but of course...
you may want something better than decent mixes!
:mrgreen:
BatsBrew
PostPosted: Fri Oct 01, 2010 2:22 pm
What monitors would you recommend? I'm new to recording so I'm still figuring out how to work logic and garageband fully and get the tones I want.
PostPosted: Thu Dec 02, 2010 10:07 pm
The HD280's are great for recording.
I would never use headphones alone for mixing. If you want a good mix, you will need good monitors and a good room to mix in. If there is a lot of bass build up in your room then your mixes will lack bass in other places because it sounded bassier in your room.
My one professor would say not to mess around at all with cheap monitors but I like my Alesis M1 Mk2 but like VigfZiel said, if you have lower end stuff the frequency response might not be as flat and could affect your mixes. If you understand this response you can compensate.
Ever seen the frequency response charts for cheap condenser mics compared to costly condenser mics? The cheap ones almost always have a bump in the high mid range where the costly ones are flat.
Carvin CT624M, Epiphone Sheraton, Epiphone G-400 (Seymour Duncan pickups), Ibanez Xiphos
ENGL E530, VHT 2502, Avatar 4x12 (hellatone 60's and G12k100's)
Monet Allums DOD YJM308, Monte Allums SD-1, Digitech GSP1101, Line 6 POD HD 500
PostPosted: Tue Dec 07, 2010 3:47 am
i use two different headphones, for recordings i use the audio technica ath-m40 which is loud and delivers a direct,full, rich, warm sound. for the mixing process i use a beyerdynamic DT880pro - awesome sounding headphone!
Joe┬┤s Band: Risky Whisky; Morbid Sky
