FX Loop light on my Mark V ON all the time
Bankim
Hi guys,
I have a minor issue with my Mark V 90. The FX loop light on the right side of the amp seems to be ON all the time, even when the FX loop is not engaged . Has anyone faced this kind of issue before ?
When I DO engage the FX Loop , the light just gets a bit brighter. I don't have a tech nearby. Getting a little paranoid because I dont want anything to happen to this amp.
Pics below :
https://imgur.com/PWezZ9Z
https://imgur.com/8Nrsfxg
Bankim said:
Hi guys,
Pics below :
What happens if you hard bypass the loop? Do you have the rear selector switch set to ‘FT SW’ (foot switch)?
Is this a brand new amp?
domct203 said:
Bankim said:
Hi guys,
Pics below :
How can I hard bypass the FX Loop ?
I have it set to FT SW at the moment and I have had this amp for about 6 years.
There should be a switch on the back right beside the send/return jacks. Check your channel volumes first though because they become the “final” volume control for each channel because the Output and Solo controls are also bypassed.
+1
Also try the different FX Loop settings and see if they work correctly when the foot switch is not hooked up (Ch 1 only, Ch 2 only, etc).
This could also be a foot switch cable issue.
