External compressor you use w/your Mark V
Discussion for the new Mark V
JD1965
Post by JD1965 » Wed Aug 14, 2019 7:37 am
Good Day All,
My longtime stompbox compressor quit on me last night.
What do you recommend for giving some extra compression to lead work?
Any help appreciated.
JD
Tucker44
Re: External compressor you use w/your Mark V
Post by Tucker44 » Thu Aug 15, 2019 3:07 pm
I've gigged a Carl Martin Compressor Limiter for about 6 years now and I would replace it if it were to quit on me. Good Luck
riggles
Post by riggles » Thu Aug 15, 2019 4:30 pm
I’ve been using the Cali76 Compact Deluxe. A nice pedal for sure, but it ain’t cheap.
Mark III (red stripe)
Electra Dyne
Recto Rack
rackmount FTW
JD1965
Post by JD1965 » Fri Aug 16, 2019 7:32 am
Thank you guys!
BMW-KTM
Post by BMW-KTM » Mon Aug 19, 2019 4:13 pm
I have a Keeley that I used to like quite a lot.
I found it to be much warmer and more natural sounding than BOSS or MXR units I had previously but all of them added noise, even the Keeley.
I think f/x like compression are the first indications of digital eventually surpassing analogue.
Digital keeps getting better all the time but it still has a ways to go on quite a few other kinds of f/x.
Compression seems to me to be an early victory for digital as does EQ.
You can crank in quite a bit of compression with nowhere near as much noise as analogue units.
EQ as well.
I have a Source Audio that literally kills any other EQ I ever tried.
bandit2013
Triple Recto
Post by bandit2013 » Sat Sep 28, 2019 3:13 pm
I use a Strymon OB.1 compressor. Keeps the tone uncolored and is not very noisy. Sustain is good too and it also has a clean boost. Works with bass too but got it mainly for use with a Stratocaster. Never really needed the compressor with the Mark V but once I tried it, hard to play without it.
