Mark IV: What's the point of having Left & Right Effect Returns?
Mark I's, II's, III's and the almight IV
SonVolt
Post by SonVolt » Sun Feb 17, 2019 1:45 pm
I get that the whole satellite feature is to achieve a stereo rig using a 2nd poweramp/speaker, but I don't understand they the Mark IV has 2 FX returns - L and R. What is the benefit of sending both returns of your Stereo FX Processor back to the Mark IV? Why wouldn't you send Return Left to the Mark IV and Return Right directly to the 2nd poweramp? Sending both stereo returns back to the IV requires yet ANOTHER cable between the Satellite Send and the 2nd poweramp. So it's basically the same thing but requires one more cable. Why?
Is there a benefit I'm missing?
ifailedshapes
Re: Mark IV: What's the point of having Left & Right Effect Returns?
Post by ifailedshapes » Sun Feb 17, 2019 3:16 pm
Check the manual on this one, since it's been a while since I owned a Mark IV and never used that feature. Anyway, I'm pretty sure the stereo loop was designed to be used in conjunction with another product they once sold - the Simul Satellite.
Guitars --> Pedals --> Amps
Past/Present Boogies
Express 5:50+ 1x12"
Stiletto Ace 1x12"
Electra Dyne Head
Lone Star Special 1x12"
Stiletto Ace Head
Express 5:25 1x10"
Mark IVb Widebody 1x12"
SonVolt
Post by SonVolt » Sun Feb 17, 2019 3:39 pm
Right, but if I understand correctly, the Simul-Satellite is just a Mesa branded Poweramp + GEQ + Speaker packaged into a combo format. Still not sure why a stereo fx processor wouldn't just route one channel directly to the Satellite, instead of sending both channels back to the IV, then going back to the Satellite. Seems like an extra hop in there for no reason.
Eevil
Post by Eevil » Sun Feb 17, 2019 4:17 pm
Output level knob affects both sends?
Current:
- Electra-Dyne
- Stiletto Deuce Stage II
- 2x12 Recto horizontal
- 4x12 Stiletto slanted
Gone:
- Mark III 60w/grx
- Studio preamp
- Roadster head
- Triaxis / 2:50
- Stiletto Deuce Stage 1
- CAA OD-50
- Mark V
ifailedshapes
Post by ifailedshapes » Mon Feb 18, 2019 3:17 pm
The MkIV footswitch has a switch to engage/disengage the loop. If you leave the loop active all of the time, then patching one output of your effects directly to the other power amp will work just fine. However, if you bypass the loop, then the second speaker would turn off with that wiring. I'm assuming that the MkIV is wired to send output to the second speaker at all times.
Again, this is a wild assumption. I've never used that setup, and I could be totally wrong.
Express 5:50+ 1x12"
Stiletto Ace 1x12"
Electra Dyne Head
Stiletto Ace Head
Express 5:25 1x10"
SonVolt
Post by SonVolt » Mon Feb 18, 2019 6:54 pm
That makes total sense. I didn't think about loop bypassing.
