Hello, I have a DRG 1984 C+ with all original caps. I'm currently in the middle of recapping. Will I hear an improvement in tone or will it just make it quieter? I'm doing all caps on PSB and the two on the EQ board. Thanks, Jim
Henz said:Thanks for the reply. I kinda understand you. What you mentioned with regards to plate voltage, my amps plate voltages at pin 3 of output tube is around 500v. My coupling caps in there now are rated at 400v. Do I need to put 600v caps there ,or am I way off base here? Thanks, Jim
