Mark IIC+ recap - huge improvement
Mark I's, II's, III's and the almight IV
thrasher10000
Post by thrasher10000 » Fri Jan 04, 2019 7:53 pm
This is probably a well established topic but if anyone has a c+ that has not done a recap it's well worth doing. Before I had the caps replaced the low end was a bit loose on the c+ which was not what I was expecting. I managed to dial it out to tighten the amp up using some rather unorthodox settings. With the fresh caps it never seems to get loose sounding even with the lead drive at 9. Here's a quick vid I did:
https://www.youtube.com/watch?v=FI6wJVF3KEM
You can get the official parts from Boogie's part supply site.
woodbutcher65
Re: Mark IIC+ recap - huge improvement
Post by woodbutcher65 » Thu Jan 10, 2019 8:19 pm
Yes, it's amazing how much better an amp sounds when the power supply is now working correctly for the first time in years!
There's no upgrade that can match replacing worn out parts with ones that are up to the task at hand.
El Rey
Post by El Rey » Sat Jan 19, 2019 4:29 pm
thrasher10000 wrote:This is probably a well established topic but if anyone has a c+ that has not done a recap it's well worth doing. Before I had the caps replaced the low end was a bit loose on the c+ which was not what I was expecting. I managed to dial it out to tighten the amp up using some rather unorthodox settings. With the fresh caps it never seems to get loose sounding even with the lead drive at 9. Here's a quick vid I did:
Sounded great!!!!
thrasher10000
Post by thrasher10000 » Fri Jan 25, 2019 9:12 pm
El Rey wrote:
Sounded great!!!!
Thanks! I just did a new one covering Leper Messiah, this time recorded properly instead of with a camera phone.
https://www.youtube.com/watch?v=mxWs-I8cge0
Honestly when I first got the c+ I was confused because I was expecting this super tight beast and it was actually the most flubby of all the Marks I'd tried. Not anymore though! I wonder how many people buy one that's due for a recap and then flick it on again not knowing how good it could sound.
El Rey
Post by El Rey » Fri Jan 25, 2019 10:12 pm
El Rey wrote:
Sounded great!!!!
Damn that sounds good!
Good job!!!
xdg999
Post by xdg999 » Sat Jan 26, 2019 11:26 am
Sounds real good!
c+ x 14, III+ x 5, D-180, Studio Preamp, 50/50, Mark V 25, Dual Rec Rev G x 2, Mini Rec and lots of Mesa cabs.
How many guitars and amps do you really need!
