6V6 tubes
Discussion for the new Mark V
jnoel64
6V6 tubes
Post by jnoel64 » Tue Sep 18, 2018 5:05 pm
I found an old thread containing a "master list" of compatible power tubes for the V. In that list, 6V6 tubes were listed as being compatible as long as Variac power was used. I also saw a combination of 6L6 and 6V6 (the V's as the inner pair) that also called for variac power and never using the 10 watt mode.
My question is: Has anyone here tried 6V6 power tubes in their V? Doesn't matter if all 6V6 were used, or if paired with the 6L6 as mentioned above. If so....how did you like the results?
__________________
Mostly Fenders with Duncans
conrad79
Re: 6V6 tubes
Post by conrad79 » Sat Sep 29, 2018 3:48 am
I too was once curious about this, and saw that same thread, but it seems there's not a lot to definitively say. Ultimately the manual doesn't mention it - and given that the Mark IV manual did mention it, it's probably safe to assume that Mesa doesn't intend for the Mark V to run 6V6 tubes. But, the manual has been updated several times over the years, including fairly major things like that EL34's should only be run on the Variac power setting, so who knows...
S.O.B. combo
Mark V head
Orange Tiny Terror combo
jnoel64
Re: 6V6 tubes
Post by jnoel64 » Thu Oct 11, 2018 2:41 pm
I took a chance and ordered a quad of 6V6 tubes. Will post my findings.
__________________
bandit2013
Triple Recto
Re: 6V6 tubes
Post by bandit2013 » Fri Oct 19, 2018 5:07 am
Good luck with that.... Not sure if you need to use EL34 bias for the 6V6 tube as you do with the TC-50 or TC-100. For some reason, I see red-plating in your future. Hopefully I am wrong on that.
dtrax
Re: 6V6 tubes
Post by dtrax » Sat Oct 20, 2018 4:02 pm
bandit2013 wrote:Good luck with that.... Not sure if you need to use EL34 bias for the 6V6 tube as you do with the TC-50 or TC-100. For some reason, I see red-plating in your future. Hopefully I am wrong on that.
This. 6V6s are typically biased around 20mA give or take. Neither 6L6's or EL34s would be biased that cold (normally). I suppose in variac/EL34 mode it might approach usable mA's... but my guess is that it would have those 6V6's running mighty hot. FWIW, JJ6V6S can take a beating. I'd give those a shot.
Guitars:
Amps:
Past:
mace
Re: 6V6 tubes
Post by mace » Mon Oct 22, 2018 8:04 am
The TC-50 takes EL34s and 6V6 tubes, with the same bias setting. The bias switch on the TC-50 has two positions: "6L6" and "EL34 6V6". So, the Mark V "EL34" setting should be close. Is it close enough? That's the question.
Beings as the Mark V will eat EL34s on full power, and Mesa updated the manual to state use VARIAC with EL-34s, I'd try Variac only.
I'm not sure what the different watt settings have on the power tubes (class A vs. AB vs. simulclass). I'd swear I remember reading that only the 45W setting could safely be used (two inner power tubes) with this type of set-up. Anyway, my guess is that there is a safe setting for 6V6s in the Mark V, but it is very particular. So, from Mesa's view, they didn't want to make an already complicated amp even more complicated so the official line is "do not use 6V6s".
Rankings: #1 Mark V head, #1b TC50 combo, #3 Rectoverb 25 head
jnoel64
Re: 6V6 tubes
Post by jnoel64 » Mon Oct 29, 2018 12:26 pm
I was on vacation for a little over a week, so I have yet to give the tubes a shot. Being a TC50 owner as well, my first guess would also have been to use the EL34 bias. The thread I dug up with a "master list" of power tubes you can use with the V is fairly old and said to use the 6L6 bias setting with the variac switch engaged. To be honest, I am a little hesitant to give this a shot, but the tonal possibilities are very tempting.
__________________
DaveRodda
Re: 6V6 tubes
Post by DaveRodda » Sat Nov 24, 2018 7:59 am
Hello...as per my observation the manual doesn't mention it - and given that the Mark IV manual did mention it, it's probably safe to assume that Mesa doesn't intend for the Mark V to run 6V6 tubes. But, the manual has been updated several times over the years.
pcb assembly process
bandit2013
Triple Recto
Re: 6V6 tubes
Post by bandit2013 » Sat Nov 24, 2018 12:22 pm
You are correct. The old manual on the Mark V also indicated you can run an integrated quad, 6L6 with EL34. I do recall seeing that when I first got the Mark V. Why would they have a bias switch? so the integrated quad is not recommended. That statement has also been removed. I believe they are carry overs from the Mark IV that was missed on the first review of the manual. There may be some confusion based on previous Mark series. Original Mark III indicated you can run the class A circuit with 6L6 tubes as well as EL34. However that has been amended to recommend using the EL34 only due to tube life issues. You can run the integrated quad with the Mark IV too. There may be other sources referencing the errors so refer to the Mesa on-line manual if in question.
conrad79
Re: 6V6 tubes
Post by conrad79 » Sat Nov 24, 2018 3:34 pm
conrad79 wrote:the manual doesn't mention it - and given that the Mark IV manual did mention it, it's probably safe to assume that Mesa doesn't intend for the Mark V to run 6V6 tubes. But, the manual has been updated several times over the years.
DaveRodda wrote:Hello...as per my observation the manual doesn't mention it - and given that the Mark IV manual did mention it, it's probably safe to assume that Mesa doesn't intend for the Mark V to run 6V6 tubes. But, the manual has been updated several times over the years.
That’s a rather astute observation that you made, DaveRodda :roll:
S.O.B. combo
Mark V head
jnoel64
Re: 6V6 tubes
Post by jnoel64 » Tue Nov 27, 2018 10:59 am
I've chickened out trying the 6V6s, lol! The last thing I want to do is damage my V. But, I will try the amp with my recto vertical 2x12 loaded with WGS Invader 50s. What that did for my TC50 was amazing.
__________________
