Tommy
:shock: What a difference!
It's sounds big and tight now, maybe a little brighter and definitely more dynamic.
Huuuuuge improvement in tone!
Orginal filter caps: 2x220uF/285V, 4x30uF/500V, bias supply - 2x 50uF/75V
...I've replaced them with
220uF/350V, 33uF/500V and 50uF/100V TAD-caps (which are relabeled F&T)
I also put some preamp tubes and now all the microphonics are gone 8)
...done the one wire reverb mod (which actually is 2 wires mod, because i've also connected reverb tank to sleeve) 8)
also installed ON-OFF switch for turning off the fan without messing around inside amp.
