Contour channel switch
F-30, 50 and 100's
Geoff Briggs
Post by Geoff Briggs » Sun Aug 19, 2018 9:43 am
Hello, I have an F50 and last night on a gig it switched from the top channel to the bottom and back several times without being asked! I never use the footswitch, and selected the bottom channel for the rest of the gig with no further unelected switches. Can anyone help please? Thanks Geoff
wildschwein
Re: Contour channel switch
Post by wildschwein » Fri Aug 23, 2019 8:20 pm
Hi Mate,
I have a Rocket 44 which has the same Contour feature on the dirt channel as the F. I have had the exact same issue you described and it turned out it was a faulty component in the power supply circuit that was causing it to switch between regular Overdrive and Contour mode by itself. You will need to take it to a tech to get it repaired -- at the very least get it checked out.
