It is currently Sat Dec 15, 2018 7:14 pm
 Post subject: Strat HH wiring
PostPosted: Fri Jul 14, 2017 2:34 pm
Does anyone have a link for a wiring diagram to wire a HH strat with a 3 way blade switch with one volume and 2 tone pots. Not looking to coil tap or split.
Can't find one.
Thanks!!!!
1991 Mark IV A
 Post subject: Re: Strat HH wiring
PostPosted: Wed Aug 02, 2017 9:30 pm
It's not like there is one diagram for what you want. Most importantly is what brand and specific pick-you have. Most manufacturers have a certain color scheme that carries throughout their entire line, but not always and pick-ups can have any amount of wires coming out of them with some needing to be soldered together and all that crap.
It's best to check the pick-ups website first.
PostPosted: Fri Jan 19, 2018 5:19 am
Here is one from the DiMarzio website that should do it:
http://www.dimarzio.com/sites/default/f ... 3w_all.pdf
Good luck,
Stephan
PostPosted: Thu Jan 25, 2018 5:21 pm
Regardless of the pickup type (I just sub the correct colors) I use Seymour Duncan's schematics. They're super easy to read and their new website lets you easily select the pickups parts & pots you have to get the right diagram. I think this is the one you would want: https://docs.google.com/gview?embedded=true&url=https%3A%2F%2Fwww.seymourduncan.com%2Fwp-content%2Fuploads%2F2016%2F05%2FTele_2H_3B_1V_1T.pdf I'm considering using this for my Strat HH project along with 1 or 2 push pull pots for single coil sounds. So far it seems the easiest route.
Also; Sorry to hijack but I have a strat HH wiring question also. Could anyone with more knowledge than myself tell me what pickup combination this diagram would yeild?
https://docs.google.com/gview?embedded=true&url=https%3A%2F%2Fwww.seymourduncan.com%2Fwp-content%2Fuploads%2F2016%2F05%2FTele_2H_3B_1V_1T.pdf Best I can tell it's a bridge HB, Single neck & God knows what else.
Again, sorry for the hijack but I hated to start another post that is also about Strat HH wiring. LOL!
DC-5B Head-Mesa 2x12 Halfback
PostPosted: Fri Jan 26, 2018 5:22 am
Thanks for posting this schematic, I would think this is exactly what was asked for.
I am not sure what you are asking - the second schematic posted looks identical to the first one.
Cheers Stephan
PostPosted: Fri Jan 26, 2018 9:12 am
Copy & paste mistake. https://docs.google.com/gview?embedded=true&url=https%3A%2F%2Fwww.seymourduncan.com%2Fwp-content%2Fuploads%2F2016%2F05%2F2H_5WSPL_1V_1T.pdf
Most of my wiring experience has been with LP's or Tele's. Still little new to 5 way Strat switch madness so this diagram was a little confusing for me. My local tech suggested I save myself some grey hairs & possibly having to buy a "mega switch" & just use the previous diagram with a tele type switch & 1 or 2 push pull pots for the coil tapping.
Was looking to pull off position 1 bridge HB/ position 2 bridge split /position 3 both HB / position 4 neck split /position 5 neck HB.
The above diagram to the best I can tell does this: p1 bridge hb / p2 both hb / p3 neck hb / p4 bridge hb neck split / p5 bridge split. That combination is just a bit too unorthodox for me.
Sorry about the confusion. Since I started my 2 HB Strat project I've been in constant confusion myself. Thankfully I have access to a competent & practical tech that got my head turned back the right way.
PostPosted: Mon Jan 29, 2018 4:24 am
It is always a good idea to start simple and then add refinements.
The super switch (that is the 5 way 4 level switch, aka 20 pole switch) is practical if you want combinations which are otherwise not or not easily attainable. Then there are the various Megaswitches by Eyb (E-type provides some of the most popular combinations for SSS, HSS, HSH or HH, P-type provides the PRS rotary selector positions and the M-type is the equivalent to the 20 pole switch). You only "need" them if the pickup combinations you want cannot be achieved with a normal 3 or 5 way switch or if you want those combinations without using push-pull pots (or if you cannot use push-pull pots in case the guitar body is too shallow to fit them). So the first question is always: what pickup combinations do I want?
Cheers Stephan
PostPosted: Tue Jan 30, 2018 12:18 am
Exactly. For me I wanted LP switching in HB mode & Strat/Tele stuff in addition. Took a bit but figured out what would work for me.
