DC-2 Problem
eiopago47
Hi,
first post here, thanks for having me.
I'm having a serious problem with my DC-2.
When I switch it on the volume keeps on cutting for about 1.5 maybe 2 hours. When this happens it's not just the volume but I get a very thin, distorted sound. After that the amp is ok and I can play without any drop outs and the sound is normal.
What could it be (power tubes, pre-amp tubes, filtering cap)? I really have no idea, any way to troubleshoot?
Thanks in advance.
Thanks for the advice, in the end it was the effect loop (which I have modded to serial).
A good clean with deoxit did the trick (as well as using a patch cable between send and return).
That's a pretty common issue with effects loops. I'm not surprised.
