Mark IIC+ vs Mark V C+ Mode
Pre Recto days. Boogie modified Fenders, Mark I-IV, Dual Calibers, etc
Which do you prefer?
Mark IIC+
7
78%
Mark V
2
22%
Total votes: 9
thrasher10000
Post by thrasher10000 » Mon Jan 01, 2018 9:36 pm
Did another shootout, thought the V did pretty well here, definitely a bit more focused sounding than the original like Mesa always like to highlight with their newer offerings. C+ sounds smoother but not as tight.
https://www.youtube.com/watch?v=boQXl0w ... e=youtu.be
dlpasco
Re: Mark IIC+ vs Mark V C+ Mode
Post by dlpasco » Wed Jan 03, 2018 10:08 am
It'd be interesting to hear the V in IV mode, triode, compared to the IC+ with PULL DEEP engaged (not sure if it was engaged already or not).
Mark IIC+, III, V, Recto Reborn, TC-50
Sold: JP-2C, V25, Road King II, Tremoverb, Electra Dyne, ROV25
Twitter:mammothguitar
thrasher10000
Post by thrasher10000 » Thu Jan 04, 2018 6:06 pm
Yeah that’s a good idea, I don’t think c+ mode is actually the ideal V tone so I should do another shootout with both amps on their optimal settings. For that vid pull deep was engaged on the c+ and the V was set to triode. Settings as per the photos if you can make them out.
JOEY B.
Post by JOEY B. » Fri Jan 05, 2018 3:27 am
Was it a 60W or a 60/100 set to 60W mode? Both of which are Pentode. If you like the "Pull Deep" use it on the C+. The only "triode" in the C+ is in the outer sockets of the Simulclass models, BTW.
"One of these days, I'm gonna change my evil ways....... one of these days.
thrasher10000
Post by thrasher10000 » Fri Jan 05, 2018 4:59 am
JOEY B. wrote:Was it a 60W or a 60/100 set to 60W mode? Both of which are Pentode. If you like the "Pull Deep" use it on the C+. The only "triode" in the C+ is in the outer sockets of the Simulclass models, BTW.
Oh wow that's really interesting, I didn't realise the non simulclass models were pentode. The C+ is a 60/100 set to 60w, pull deep engaged. Triode setting was for the Mark V, it's a two-way switch between that and pentode regardless of which wattage mode you have it set to
