It is currently Sat Aug 18, 2018 1:08 pm
PostPosted: Mon Dec 18, 2017 9:47 am
Hi All
apologies if this question has been asked before, but i can't seem to find any information on this.
My friend recently acquired a '92 dual rec (S/N R-002419) but doesn't have a footswitch for it. I can't seem to find any schematics for the fs anywhere.
From the looks of it i would say it's a TR cable going to the switch, but mesa has 2 switches for sale on their page: LED version and no LED. Does the amp provide power via a TRS cable for the LED or does it need a battery?
also, is the footswitch a momentary or latching switch?
Thanks
Tim
PostPosted: Tue Dec 19, 2017 3:34 am
Looks like you need this:https://store.mesaboogie.com/products/footswitch-channel-switching-single-button-with-led.html and the matching cable.
2012 Mess Boogie Dual Rectifier Roadster Head
PostPosted: Tue Dec 19, 2017 9:21 am
I want to make my own.
PostPosted: Wed Dec 20, 2017 11:20 pm
The 2 channel DR heads use a TS cable and need a latching switch to make the channels change.
The footswitch jack will send current through the cable to power the LED (i.e., you do not need a battery to power the LED), but from what I remember the LED needs to bridge the terminals of the switch to create a voltage drop to change the channels when the LED is in the circuit.
I'm pulling this from memory (my amps and their switches aren't here so I can't open them up and check), but I can confirm the footswitches from both my current tremoverb and the 2 channel DR I had several years ago did not have batteries to light the LEDs and the footswitches were basically a jack, a switch, and an LED in an enclosure.
PostPosted: Thu Dec 21, 2017 1:22 am
Awesome! That’s what I was hoping for!
