Rectifier + Mooer Radar (stage sound performance and rec.)
Area about recording, mic techniques, production, mastering, etc.
Moderator: Nick_cor
JensMrqn
Post by JensMrqn » Tue Nov 28, 2017 11:30 am
Hi guys,
First of all: I'm new here. If the post is in the wrong board, shoot me.
I wanne use a cab sim for recording and a more straight sound on stage. I've decided to use the Mooer Radar because i'm on a budget.
After a bit of research i noticed that i can use the slave output on my rectifier for a line level sound with pre-amp and power amp from the rectifier.
Question one: What is the slave output mainly used for? The recto manuals desciption is not pretty clear in my perspective...
Question two: Can i run the slave out throught the Mooer Radar (or similar cab sims) without running the amp throught a cab? (Which would be awesome for recording at home.)
Question three: If not, what do i need to do to create a line level signal with power amp signal running throught the Mooer Radar?
Question four: Is the slave out signal dependent from the master volume?
It's a big new puzzle for me and i don't want to blow up the whole thing. I'd rather know too much than just not enough. Help!
Kind regards from Belgium.
domct203
Re: Rectifier + Mooer Radar (stage sound performance and rec
Post by domct203 » Sun Dec 03, 2017 7:20 pm
Welcome to the forum
One: The slave out is designed to be used to ‘slave’ the amp to the input of another power amp or effects rack.
Two: There must ALWAYS be a speaker load connected to the amp, even if using the slave output. Failure to do so can destroy the output section of the amp (powertubes and or output tranny).
Three: You will need a ‘dummy load’ on the speaker output to use the slave output silently. Another option is a Mesa Cab Clone.
The Slave output is taken from the output transformer, it will be after all amp controls.
I hope that helps,
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V - sold
‘18 TC-100
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
Voodoo Labs MIDI
==> NOMAD on Facebook <==
desertdweller
Post by desertdweller » Sun Dec 24, 2017 2:56 pm
Here's a simple way to do it and retain what you want. If you have any effects pedal that can split into stereo (like a reverb, chorus, or multi-effect pedal or rack), run it last in your chain. Run one mono output from it back to your effects return on your amp, run the other output to something like the Mooer Radar, and let that output go to the house. You can run your amp with your cab for your sound on stage without needing to mic it, and you have complete control over the sound that goes to the front of the house.
The slave output is not useless, but it's dated. I'd rather have my sound with full effects going to the house than have to run the slave (which is just the preamp sound) out to something. At the very least to include a noise gate :)
domct203
Post by domct203 » Sun Dec 24, 2017 3:44 pm
desertdweller wrote:The slave output is not useless, but it's dated. I'd rather have my sound with full effects going to the house than have to run the slave (which is just the preamp sound) out to something. At the very least to include a noise gate :)
The Slave output comes from the Output Transformer, and will include any effects that are in the FX Loop. It is NOT another preamp split.
This is explained in the amp’s owners manual.
Dom
'10 Mark V - sold
‘18 TC-100
'74 Les Paul Custom
'95 American Strat
Voodoo Labs MIDI
