It is currently Fri Jan 18, 2019 7:30 pm
PostPosted: Sun Nov 19, 2017 7:22 am
Has anybody used this combination? I experienced the builtin eq with the JP2C and it is dramatic. How would that pedal work on the Lonestar?
Mesa Lonestar and Kurt Wilson Guitars
PostPosted: Sun Nov 19, 2017 1:25 pm
I've wrote something about this combination in a topic (link below) about some people finding the Lone Star Drive channel to bassy. I use the 5-band EQ pedal from Mesa with the Lone Star Classic and it works great to sculpture your tone even beyond the EQ possibilities of the Lone Star!
https://forum.grailtone.com/viewtopic.php?f=31&t=71878&start=15
PostPosted: Sun Nov 26, 2017 12:23 pm
Certainly a cheap upgrade, and a very good idea LoLands .. Btw: where are you based?
PRS 2 Channel 50
Carol Ann Triptik R
Carol Ann OD 3R
Carol Ann Tucana 3R
Carol Ann 10th Anniversary
Redplate Aurora 34
Marshall Anniversary 4X12
PRS 2X12
PostPosted: Sun Nov 26, 2017 4:28 pm
Not the cheapest EQ pedal but its a good one! Before the Mesa i had the Boss and MXR EQ pedal but the Mesa doesn't add any hiss or other noise. I'm from the Netherlands btw.
PostPosted: Sun Dec 03, 2017 8:54 am
Thanks for the advice LoLands. I bought a Mesa 5 band EQ and am trying it in my amps. I see exactly what you mean by tightening up the bass response with the 240 slider on the Lonestar. A clearer, tighter bottom end which responds well to pick attack. No longer boomy or flubby when gain is past noon, and I can add a little more bass through the pre-amp to fill out the tone
One thing I learned quickly - taking a frequency away is effective, but changes the overdrive response significantly, which I don't nescessarily want. It smooths it out too much, losing its bite. I am now experimenting with reducing the 240 slider, and adding other frequencies in equal measure, which seems to be working better through my rigs
I would appreciate any further advice based on your own experience
Thought you were probably from Holland .. I am Belgian living in the UK
PRS 2 Channel 50
Carol Ann Triptik R
Carol Ann OD 3R
Carol Ann Tucana 3R
Redplate Aurora 34
PRS 2X12
Users browsing this forum: No registered users and 0 guests
