JP-2C at mid gain!
Discussion area for the new (and first) Signature Model from Mesa Engineering.
donnyboiler
JP-2C at mid gain!
Post by donnyboiler » Tue Oct 17, 2017 7:52 am
Nobody ever talks about what the JP-2C can do at mid-gain, so I decided to put together a studio test of its capabilities. I used a Suhr Classic T on the left channel and a Suhr Classic Pro in the bridge humbucking position on the right channel. It’s a Darkness track and I used the second channel with the gain below half for both guitars. I also added a couple of solos just for a bit of context, which I did on channel three with higher gain; first using the bridge position of the Classic Pro, and then the neck single coil.
See what you think!
https://soundcloud.com/end-of-the-centu ... ogie-jp-2c
richprice79
Re: JP-2C at mid gain!
Post by richprice79 » Fri Oct 20, 2017 9:38 am
It sounds great man. I think these boards are pretty dead though. As an owner of the JP2C LE I hope it does well in the market though it appears they haven't even sold out of the limited edition model yet which only had 325 made. I think the digital toys have cut the amp market deep. I don't mean to hijack your thread but as a fellow owner what are your thoughts? In the end I have mine and sales don't really concern me but I would love to see this model have legs and not become a relic that never caught on.
kingb
Post by kingb » Fri Oct 20, 2017 1:11 pm
nice sounds - what are you using to record (mic, pre, etc...)
FYI - I just got an sE guitaRF - which makes mic placement and phase alignment super easy and consistent. Getting ready to do some recordings myself will post once I've got some stuff.
@richprice79 - I've got the LE as well. I know what you mean though about the amp market - although I kinda see the entire guitar market as oversaturated (see what I did there)... surely a correction is coming, but we all should be better off as the quality stuff should stick around. No doubt "digital" makes things convenient - but there's still just no comparison to the real deal. Right tools for the job though. If I had a fly gig then throwing a Kemper toaster into a suitcase would be the way I'd go (after profiling the JP-2C and a few other toys).
mace
Post by mace » Sat Oct 21, 2017 10:45 am
donnyboiler wrote:Nobody ever talks about what the JP-2C can do at mid-gain, so I decided to put together a studio test of its capabilities. I used a Suhr Classic T on the left channel and a Suhr Classic Pro in the bridge humbucking position on the right channel. It’s a Darkness track and I used the second channel with the gain below half for both guitars. I also added a couple of solos just for a bit of context, which I did on channel three with higher gain; first using the bridge position of the Classic Pro, and then the neck single coil.
See what you think!
Great playing and nice little hooks on the solos. Crunch sounds good on the rhythm parts.
Mace
Rankings: #1 Mark V head, #1b TC50 combo, #3 Rectoverb 25 head
donnyboiler
Post by donnyboiler » Sun Oct 22, 2017 7:55 am
Thanks dudes. It’s a Torpedo Live with an Ownhammer V30 sim. Bit of reverb applied in Logic and that’s about it.
