It is currently Fri Dec 14, 2018 8:12 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: LSS Chassis Bolt
PostPosted: Sun Nov 28, 2010 8:16 pm
I needed a laugh today, the funny thing is I just found this screw myself today and was wondering all the same stuff.
You guys are too much.
Vogelsong
G&L Comanche,
G&L Legacy,
RI 64 Vibroverb Custom
Original 66 Fender Reverb,
Original 59 Fender Bandmaster,
69 Fender Coronada II,
51 Gibson ES300,
Beater Strat,
Waldon Acoustic,
PostPosted: Sat Jun 23, 2012 3:16 pm
I replaced mine with a cryogenically treated screw! Sounds much better now.
PostPosted: Mon Jul 02, 2012 4:53 pm
I would think you would have to back this screw off a bit when sliding the chassis out or you might rip the foil shield.
Is this correct thinking?
Thanks, Ron
PostPosted: Mon Jul 02, 2012 7:04 pm
Thanks, Ron
Yes. Remember to drain the caps, because sticking your hands inside the chassis can kill you.
PostPosted: Wed Dec 04, 2013 7:22 pm
Would it be possible for a loose shard of foil to fall down on the circuit board or tube socket and short something? I'm thinking about screwing a small repair plate there, 2" X 2" made of aluminum sheet metal.
My RoV2 had signs of an arcing on a tube socket when I got it,(used). Now I'm wondering if it was a shard of foil. My foil is all chewed up there.
'02 ROV 50 II Combo
PostPosted: Fri Oct 21, 2016 8:54 am
What that screw is doing is completing a Faraday cage. Contacting the foil of the cabinet it's sending the small charge running through the chassis, to the foil. This stops a lot of EM/RF noise.
As for repairing the foil, a bit of copper tape will work fine.
Recently put my Mark V in a headshell that didn't have the foil. It was a bit more noisy and the footswitch clicked/popped.
Put it back in the combo housing and all is fine.
some guitars and some amps
PostPosted: Thu Sep 07, 2017 3:54 pm
I think it says something very positive about Mesa that they would even think about a "tension screw" to help prevent buzzing of the chassis against the cabinet.
I mean...what other amp maker does this?
I'm a Mesa Boogie newbie, but this is just another reason I'm soooo glad bought a Mesa amp!
Thanks, Mesa!
PostPosted: Tue Oct 17, 2017 5:28 pm
Triple Recto
The RA100 combo has the same thing going on with the tension screw. Never seen one on the Roadster but there is a square hole in the chassis of the Mark V that appears to have been something deleted.
I guess no screw would make things airy, that is great as I play 'air' guitar most of the time anyway. (I know... to late..... )
PostPosted: Tue Jan 02, 2018 9:51 am
Well, the screw is not therefore to make contact with the foil. Because there are 4 screws on the underside of the chassis to make contact to the foil and make a faraday shield to protect against RFI.
You can see that very well in the picture of a Nomad 55W I found in the internet.
( Bare screws on the left and right )
cron
