Effects loop causing sound to breakup on LSS
Classics and Specials
FastFingers
Post by FastFingers » Mon May 15, 2017 9:35 am
Hi all,
I have a Lonestar Special and absolutely love it. However, I've had a recurring problem.
Every now and again the sound fizzles out (completely out), and comes in and out at random. I've isolated the issue to be within the effects loop. If I hit bypass switch the problem is gone.
It went back to the store and they were advised by their Mesa distributer that it was just the pre-amp valve in the effects loop. They switched it out, it's been fine for a few weeks and now it's happened again. It's already been back to the store on two occasions and is likely to be going back again.
I only use the effects loop to have use of the master/solo boost volume controls so I can get by without it. I just shouldn't have to.
Anyone got any ideas I can take with me back to the store?
All the best.
Phil.
Blue Fin
Re: Effects loop causing sound to breakup on LSS
Post by Blue Fin » Mon Jul 17, 2017 10:20 am
Phil,
I have been experiencing the exact same problem with my LSS during the past two weeks. Have you been able this issue?
Thanks,
Mike
2006 PRS Custom 22 (Vintage Yellow)
2004 Gibson Les Paul R0 (Washed Cherry)
2009 Parts-O-Caster (Bahama Blue)
Lonestar Special
